HELP! Stuck in Recovery & home screen is unresponsive
627gigi
My Epic 4G was constantly powering off & I read that a reset was the way to go... so I was able to get into recovery mode but now I can't select an option b/c my home button on the touch screen will not do anything. :mad:
I searched the forums & saw that the camera button might work for selection... tried that & it didn't work for me. :confused: Is there a manual or keyboard way to choose the selection or back out of recovery mode?
Thanks in advance!
Pull battery and reboot. There should be an option to do a data reset from within Android. It will boot to recovery and perform the action automatically.
Sent from my SPH-D700 CM9 4.0.4
Every time I take out the battery & put it back in then power on it's still on the recovery mode screen. I can make it go into download mode by pressing 1 on the keyboard & power simultaneously but I don't know how to make it power on as normal since my touch home button won't respond and I don't know of a keyboard button sequence to do so.
Out of curiosity, have you tried to use the physical "home" button on the keyboard?
I found the answer!!? It's the enter button on the physical key board. I know this will work, hoped this helped :)
Isaiah1110
