• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Help! Tablet says storage full, but not sure why.
gnr_2
906
Hi all,
I have a N7 2013 Wifi edition. It is rooted and I was doing a ROM update. I did a factory reset, flashed ROM and a minimal gapps package then wiped cache and all that. Rebooted, installed My Backup Pro to reinstall my apps from backup and it is saying that all 26 GB are full. I have about 9 apps that installed from the backup, the rest are system apps.
What is going on? What should I do to fix this?
TIA
Sent from my "no longer 120° or battery guzzling" Sprint Galaxy Nexus, thanks to help from the AC forum
gnr_2
906
PS I started the process over and same thing. Like 250 MB free with no apps installed. When I'm in recovery it says internal storage is using 360 MB so I don't know where the disconnect is or how to fix it. Also my recent nandroid backup keeps failing when trying to restore so that's not an option either. 😥
gnr_2
906
Found answer over at XDA. Turns out it was the Nandroid backup files taking up all the space.
Sent from my Nexus 7 using AC Forums mobile app
