Help! trying to go to stock 4.2.1 but it says baseband does not match
Omienice
Long story short, I received the Nexus 7 as a gift from someone at Google. However, when I tried to update the Google app, it said the app wasn't signed. So i tried a bunch of things. Now I am trying to put on stock 4.2.1
This is the 3g version.
Tried to do everything and when I tried to fastboot the stock image, I get a message that
Device version-baseband is '1231_0.10.0_1020'.
Update requires '1231_0.10.0_1021'.
How do I go about getting this thing to work?
Nicolas Pipitone
Not sure if you got this fixed but I found on another site that you have to flash the radio first.
"flash radio radio-tilapia-1231_0.10.0_1021.img" or whatever the radio file you have is.
Do this after you flash the bootloader but before you do the update part.
Hope this helps.
Nixx
cognus
121
go to xda forum and get Mark's Nexus 7 Toolkit , install it on your pc, put the device in fastboot and hook it up. pretty much everything you can possibly need will be there on his menu. and send him a donation - it is fabulous work
john papa
