HELP! trying to unroot evo and stuck!
Well if you tried to unroot did it finish the process? Did you flash s-on and flash the PCIMG36.zip in.bootloader? Try pressing the power and volume up and down keys while on the red triangle screen. It should put you in stock recovery so you can reboot.
Sent from my PC36100 using Tapatalk
I tried to flash the s-on and to be honest im not sure it went through.. it may have failed.. (wasnt paying attention :-! ) I put the PCIMG in and i noticed that it failed on system
if i could load a zip into the phone i would put a recovery in and probably be okay from there.. but i still need help..
i would love for it to boot up but i figure a recovery is probably step 1
Is the PC36IMG zip file ur using the correct one for your phone? Take a look here and make sure that you're flashing the proper one that is configured to your radio:
Supersonic Shipped ROMs - xda-developers
Make sure you're using the right one, see if this helps.
Nautius Maximus
