Help!! WIFI Issues
Fryguy128
45
I recently rooted my phone and am now having wifi issues. My wifi was working fine then I flashed another kernel and couldn't get wifi. I then updated the phone and it worked again. I changed the kernel again and can now not access wifi. There aren't any updates so I need help.
You don't mention what kernels you are flashing. I have been using Cyanogenmods ICS nightlies for a couple of weeks now with no problems and wifi is great.
did you fix the issue... thinkin about rooting. like to here when you resolve the issue.
I fixed the problem by flashing SHOstock. I would definately recommend rooting to you I love it so far except for the occasional problems that are very easy to fix with a quick Google search.
Reactions: webbie2
rvrsco
