Hello all, I have a Nook Color that was rooted and running CM7 from internal and was running good. I wanted to see how Honeycomb performed on it so I backed up w/ Clockwork Mod and then installed Rom from Zip w/ CWM. Unfortunatly, I forgot to unplug it from the computer (it was just charging not being used as USB) and during the installation the cord came unplugged.
During installation the bar that typically indicates progress did not move or fill AT ALL. I don't know if this is normal for this build or if it is related to my conundrum.
Upon booting, the NC now just shows 'Loading..' and eventually the screen flickers, it then displays 'Loading...' again but higher up and only for a second before all it does is show the word android all in caps in a small font and sky blue with a litlle blinking underscore following it and in landscape mode.
I have since tried booting (power + N) into CWM to utilize my restore but for some reason it always does the same thing.
At this time I don't have access to a computer that I can utilize to reflash my USB (I'm on a work computer) so that is not an option for me.
Any suggestions would be greatly appreciated
