Help with charging times (bumblebee 2.4)
cybermaniak
77
Hey guys I?m using Bumblebee 2.4 and its?s taking a lot time to charge.
I have been watching carefully and 1 percent is taking around 6 minutes, that would be 600 minutes to charge a 0-100% = 10 hours ....
It?s this normal ??
when I was on stock rom (rooted only) it didn?t take that long...
I have 3 cables and with all three is the same..
Any clue ?
It?s this normal ??
Any clue ?
Either your battery is crap or you need to recalibrate your battery.
I'm on bumblebee 2.4 and it only takes about 2.5 hours to fully charge when I dont use it. But when I use it as its charging, it can take really long.
This problem only started when I did the rom change.. How to recalibrate the battery ?
Go into recovery and wipe your battery stats, should be under advanced where wiping dalvik is.
I haven't used bb2.4 since I started testing ath3nos but it never took nearly that long to charge my battery.
Thanks.. and that could be done either if its not fully charged ? only plugged to the wall ?
Found some instrucctions... is this correct ?
Charge to 100%
Clean batterystats (from recovery mode)
use the phone until the battery is dead (the phone turn off)
and charge again.. (with out touching the phone)
Charge to 100%
Yeah, I would just do those steps and then see how it goes.
Could also be a problem with the install you did so if that doesn't help I would try doing a fresh flash and remember to wipe everything.
Jokerman
