Help with color on my phone
Mar 15, 2014
5
My Samsung Galaxy note 3 said it needed to upgrade something and when it started back up my screen was black and my battery icon, WIFI and others things are like a negative gray. I want my white color back with my white phone. How to I get it back?
Welcome to Android Central :)
Could you post screenshots of what it looks like?
Sent from my Galaxy S4 running SlimKat 4.4.2
This will be the fastest way for us to identify what the issue is. For reference, you can grab a screenshot by holding the power and home buttons down simultaneously until you see/hear the capture. I would also ensure that the "negative colors" setting is disabled, it may have been turned on inadvertently:
Settings > Device > Accessibility > Negative colors​
This is what it sounds like to me. Didn't know it was an option in stock TouchWiz
Palm motion should also work for screen shot if enabled. Some might prefer it over the home+power button method
dpham00, Android Central Moderator
Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
Nope it was the Android 4.4.2 that is screwing with my phone. I can't type on my online banking. It is showing in black and not letting me type and also taking a while to select something
Reboot into recovery mode (Volume up + home + power) and wipe the cache partition. See if that helps with the delays. It won't delete any user data so you don't need to back any thing up
How often does the Android software update? I am not liking the 4.4.2
Not very often. At least major changes, so I wouldn't expect anything soon. Maybe 5-6 months at the earliest (for the Note 3)
I suspect that over the course of the next couple of days you'll get used to it. :)
Thankfully the changes in 4.4.2 itself are relatively minor on the surface, so as Kevin said, you'll probably be used to it in no time. I'd say the improvements under the hood, so to speak, are likely worth the adjustment to UI changes — though some may say otherwise. :)
grastyvirginia200
