Help with Galaxy Note battery and yiboyuan universal battery charger ?
jaenixlee
Hello there.
I just purchased a new battery and it came with the yiboyuan universal battery charger.
According to most posts, it's supposed to be red while charging, and blue when fully charged.
However, when I plugged my uncharged battery in, the light turned blue, not red.
I know for sure it's not fully charged because I just took it out of my phone and it was at 30%.
Hello there.
Try stock charger and cable
From my Galaxy Note 2 via Tapatalk
When you put the battery in (unplugged) it turns blue, then you know it is in right. Plug it in, and it turns red. When it is done, it turns purple. It is weird, but works, especially if you have a second battery and want to charge one while you use the other.
If you have the same model as I, the prongs are moveable. You have to make sure they line up correctly, positive on the left, negative on the right. The battery should label + and -.
Gillian Kirton
