Help With Huawei P20 Pro Glass
mlee1999
236
Hi i just picked up a P20 Pro and like the phone however similar to the P10 Plus it has a factory screen protector. I would like to take the screen protector off but I am concerned the glass does not have the oleophobic coating. Has anyone tried removing the screen protector or know if there is a coating on their Gorilla Glass? Thanks.
Huawei has said both sides do, I took everything off including the screen protector so far it's been fine, the back is more prone to fingerprints than the front.
Thanks I ripped mine off today too cause I was tired of it and read the later P10+ had the coating. You're right it has some type of oleophobic coating. I'm much happier.
marksains61
