Help with icon on Nexus 5
granty1970
Sorry for being an *****, I have a Nexus 5 and upgraded to Android 5, since then I have noticed at the top I have the clock, followed by battery indicator, then signal and wireless icons, i now appear to have a 'No entry' type symbol.
My phone appears to be working fine, what is this symbol and do i need to worry?
Many thanks
You must have set "No interruptions". Unless you don't want any interruptions due to phone calls/text/etc, use volume key, and change to "all"
Just hold the Volume Key all the way down to the bottom and a window will pop up where you can choose from No interruptions, Priority, or All.
No Interruptions will give you that circle with a slanted line through the circle, Priority Mode will give you a solid white star, and All will not put any icon in the Notification Bar.
Posted via my Nexus 5 with Lollipop
Cs Kredivo
