Help with microSD cards
tony5496
24
Hi all I am just looking to get microSD card for the Galaxy S5 I was just wondering if someone could help me out. I am looking at the 64 GB but I'm very confused about the class what does the class main class six class seven class ten ! it's all very new to me any help would be great and if you could recommend a good one to get for the s5 :)
The class of the the card basically boils down to the read/write speed, the higher the class the faster the card. I've always used SanDisk, using one now 32gb Ultra, never had a problem but others have reported some issues. Stay with the leading top brands and you should be fine. And that really is a good deal on that Samsung card posted by PsychDoc!
I just asked the same question in this forum and decided to by the SanDisk Ultra 64 Gb card for both my S5 and Tab 3.0. Speed was not really a consideration but high reliability was. Good luck.
Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
sas9111
