Help with mobile site
jayhawkfan18
A Dude
May 14, 2010
416
13
I cannot seem to access the mobile version of any websites... specifically m.break.com
No matter what settings I adjust in the browser it takes me to the full site every freakin time! Anyone know a way around this?
Sent from my ADR6300 using Tapatalk
If your using the stock browser the only setting I know of is menu>more>settings>then make sure you have mobile view checked. If it still doesn't work you might want to try Dolphin or another browser.
Thanks for your reply. I am using the stock browser and I have tried changing that setting. I even cleared cache/cookies to see if that helped. Nope. Prior to froyo I visited the mobile version of that site often.
I even tried Skyfire. I guess I'll try Dolphin browser too and see if that will get it done..
Sounds pretty strange that you are able to access some mobile sites but not the one you want. Good luck finding a work around.
Thanks. It is very weird. I can even get the mobile version of this site. & Dolphin did not work either BTW
