help with recovery
Nov 9, 2013
8
i used odin to root with the CF-Auto-Root-d2vzw-d2vzw-schi535.tar.... i have root access via root checker but i dont seem to have a custom recovery and i dont know if i unlocked the bootstrap... all i want out of this is a kernel and a rom with the best batt life. i have a i535 and im going to put it on walmart tmobile for 35 a month... i also need to edit the apn to get the data working when i get the sim card and all that friday. i have tried to use apn manager pro and it can save my apn. so i guess my question is where do i go from here to get all these things possible?
Bootstrap? I think you mixed the terms safestrap and bootloader XD
Anyway, I found this thread on xda ★[8/27] [Casual] [Root, Unlock, Recovery] Vzw S3 Toolkit or 1-Click!! [ALL OTA's]★ - xda-developers for the VZW GS3 :)
ok i have a custom recovry now but what is the best rom for no bloat and best bat life i also need on that will let me edit my damn apn
I'd recommend SlimBean 4.3 :D
The idle drain is almost nonexistent. I've gotten almost 7 hours of screen time on my S4
There should be one for it. Look for Verizon S3 SlimBean
Yes you can flash both from internal memory. As far as flashing kernels just follow instructions from the Site where you get it from. Roms just flash as usual.
Sent from my SCH-I545 using AC Forums mobile app
kiki2025
