Help with Revvl phone GUI
ozpod
Hi I recently bought a Revvl 7 phone. Since day 1 it has had a lot of minor yet frustrating features, which looking through settings and online I've found no way to easily change.
My old phone used the three button navigation feature, which I am used to using. However, Revvl places the return button on the left side of this panel while my old phone placed it on the right, which by years of muscle memory has caused me mistakes. This seems like a minor inconvenience which should have an easy fix, but Revvl as far as I can tell doesn't allow this to be changed. Another feature I find annoying is the scroll bar with the apps. My old phone when you had too many apps for a page would simply make another page you could swipe to. It wouldn't be too bad if I just had to get used to this, but instead there it is in a weird half-way position where from the home screen I can swipe right and left for different pages, but when I swipe down it always takes me to the scroll bar, so I still have the muscle memory of multiple pages, but being interrupted by a scrollbar. I also don't like the minimalist art style to the everything.
These and other things are just minor things that I'm sure I have to get used to eventually since I'm stuck with the new phone now, but i would really appreciate it if someone knows of any good apps or tools, etc, which can change GUI features that I don't like or don't find intuitive, to save myself some frustration.
FYI I just made an account and I'm not any kind of tech geek so simple explanations would help.
Heritagesa01
