Help with setcpu
cl36
168
15
I downloaded the setcpu app yesterday to help with audio cracking. After I set the minimum to 200 the cracking issue was resolved. Last night my battery was about 50% before went to bed and about 7 hours later it was completely dead. Is it ok to use setcpu on the fascinate running the stupidfast v1.54 and if so at what settings.
SetCPU does not play well with the Fascinate. You can choose to use it but it will cause way more headaches than benefits.
IMHO: Stay away. Flash an undervolted kernel that has the audio issues addressed. Adrynalyne makes a great one.
The other option for me was to use the stupidfast 12/20 test - that cleared the audio issue and is also undervolted.
