Help with speaker phone please.
kaufmansm
174
when i flip over the phone to put in speaker phone mode it does not always work. Any help would be appreciated.
Make sure you have it set to do this: Menu | Settings | Sounds | Flip for Speaker [checked].
Also, what I have noted, is that the surface must be nice and flat. Just holding it upside down in your hand usually will not work. Neither will laying it on the car seat next to you. Lay it on a desk or table face down.
Also, the speakerphone volume is set separately from the normal voice and ringer levels. You might need to check the speakerphone volume first to make sure it is turned up high enough you can hear it.
Edit: Also, just to be clear, you have to already be on a call before you lay it down on a table.
-Frank
I read if your ring is set to vibrate or silent the flip for speaker phone won't work. Turn your ringer up and try it again.
Not true. The post above of spot on. For some reason it must be completely FLAT and LEVEL. weird.
Sent from my ADR6400L using Tapatalk
slametmunawir010796
