help with usb debugging
Oct 12, 2012
Hi, I am looking for help with my samsung replenish. I am using an Odin downloader to root my phone, after wiping my phone completely clean!!. The problem I am having is getting the pc to recognize my phone is connected. I am unable to access usb debugging because I cannot load up my os! Is there a way to access the usb debugging through recovery mode? or possibly an alternate pathway? Thanks for any advice you can provide!!!
are u booting into CWM recovery (hold 'U' while booting)? it should say cwm somewhere on the screen
Install drivers. I believe one to be somewhere in an older rooting thread maybe, also yes, easiest way for me is pull battery, put back in, while holding space+u, plug usb in. If u have cwm flashed via odin u should boot up and abd will reconize and u can mount everything there.
What exactly u trying to do?
Sent from my SPH-M580BST using Tapatalk 2
boone
