Help with Verizon login client
honex97
277
7
So I've been trying to use the NFL app for Verizon and it asked me to download the Verizon login client so on the market it says not compatible so I searched Google and found the apk on roozwiki so I've been trying to log into the NFL app and when it takes me to the Verizon login client I sign it and it always says service temporally unavailable and its been doing this for about a month.
Right now I'm running cm10 on my nexus but its done this when I had stock ICS. Anyone have any advice?
And also sometimes it will sign in and ask me to create a security question so I do and then it tries to load and says service temporarily unavailable again
No problem! Last year I had to make sure the NFL app worked with thunderbolt roms before I'd flash them.
Sent from the north woods
My "my verizon" won't work it opens and when I go in on WiFi I get "services are temp unavailable" if no WiFi I get "a free Verizon connection is unavailable please try again later" I'm running vicious jellybean.
Arent they charging for the NFL this year? I gave up with my vz would like it to work just to watch the account.
Yeah Its $5 a month
I've seen threads like this on many different forums and every single one ended with the op saying he gets service unavailable when logging into the login client. i am getting the same and haven't seen a single solution posted anywhere about it yet. anyone?
When I last flashed, I had to uninstall the My Verizon app I had, and then use the files from this zip:
https://www.dropbox.com/s/z6des6xknfihunz/MyVerizonGalaxyNexus%26VZWAPN.zip
VZWAPNLib and VZWAPNService had to be in system/app, and MyVerizon and VerizonSSO could be installed as normal apks. I had to then launch My Verizon, the old version, and it would work. Then I could update to the latest version. If I updated to the latest version before launching, I would get the unavailable message. Not sure if it'll work for you, but it did for me.
Edie Raleigh
