Help with wifi not turning on after repeatingly pressing on the toggle?
izgmoen
10
I have a rooted samsung galaxy s4 from verizon running 4.4.2 and for some reason my wifi stopped working! :(
I have already tried factory resetting, and pulling the battery out the phone when its on and off as well as waiting for seconds. Also I have disabled all of the samsung knox related apps and removed them except for the klms agent one. Idk if its hardware or not but when I tried turning on the wifi when I reset the phone, It said something like 'your device's security has blocked an action that is not permitted". I'm about to lose it already cause I really want my wifi to work again cause I have a 1gb data cap lol. :( THX!
A member recently mentioned in a post how he could only turn on wifi if he turned on Airplane Mode first. Worth a try?
Sorry. Try poking about in Settings, Security and see if changing any of the settings...temporarily at least...does anything.
'Your device's security has blocked an action which is not permitted' is what I was thinking of. What it means I don't know but I thought you might be able to disable this or that in Security to get it working.
I've lost the ability to post links but if you go Android Central Community/Help and Advice/ Guides and How To (or something like that) you'll find B.Diddy's wifi guide which may help.
It's Forums/ Android Central Community/General Help and How to/Ambassador Guides etc/(Guide) Troubleshooting Wifi etc. Author B.Diddy.
If you can find the thread called Not Connecting to Wifi, here in Ask A Question, there's a link in it to the piece. I'm sorry I can't post a link myself, don't understand why, always used to be okay. I guess I just got out of clown college.
hlx130
