Help (Yellow Triangle)
flyinb501
Active member
Dec 16, 2010
29
Hey Guys, I'm a noob to all of this but decided I would try and root this phone on the advice of a friend. Well I am now stuck on the yellow triangle screen.
All I did was the Odin one click method with EL26 using this file:
http://www.rwilco12.com/Files/Devic...is41g/Stock CWM/One-Click/EL26_Stock_CWM5.exe
It said "pass" when it was finished, but when the phone started to reboot it just got stuck on the yellow triangle screen. Please help!
Try flashing back to stock and starting over. rwilco files are good, but probably a bad download.
Thanks for the quick reply. When you say flash back to stock, do you mean one of these? Does it matter which OS I use (ICS, GB, JB)?
Rwilco12's Android Repository - Downloads
You need to download the os that was on the phone before you rooted it if you can't remember which it was type the name of your phone into Google and see which version of android it uses and one last thing Odin is a neat little app but flashing a ROM using your PC/laptop is a lot more stable.
sent from my Nexus 7 using tapatalk pro..
Download GB 27. Assuming you are on Sprint.
Okay, thanks. I know I was on ICS so I used the ICS FF18. I'm back up and running now.
Do you have a link?
Check out QBKing77 on YouTube. He has some great videos on how to root.
I would just use rwilcos.
So on his site if I go to:
Root > Files > Devices > Samsung Galaxy S2 (Sprint) (SPH-D710) > Stock ROMs > JB > GB27 > Full Restore
Do I choose rooted or unrooted? I'm pretty sure the phone is still not rooted. Will this root the phone, or will it just put the new stock ROM on their?
For whatever reason his root files are hit and miss. I would go unrooted and just root later.
tepota7360
