help?
shane1316
6
Ok I dont have a clue what im doing. My thunderbolt is lagging bad. I have talked to a few people about rooting my phone and doing a new ROM. The problem is how do I tell what I'm running now. I see somepeople are running GB stock and froyo stock as well. All i want to do is make my phone faster battery last longer and free hotspot. Thanks
Are you already rooted? Or are you running stock?
And to check your software hit menu>settings>about phone>software information
Android Version 2.3 = GB and 2.2 = Froyo
Reactions: shane1316
Well there's really no way to just get a feel for gingerbread, unless you know someone that has the update or another phone that has gingerbread. If you decide to root, I suggest reading through the steps outlined in this forum thoroughly before you dive in. It's a fairly easy process and the end end result will be a much better working phone.
Ok so I think I can do the revolutionary root. after that can I make my Froyo to Gingerbread with out any problems? I see that it has a few out but I want to make sure my camera and 4g still works it looked like some of these ROMs could make these items not work anymore
Oh ya it will work just fine, after you root though make sure you download ROM Manager from the market and do a back up of your current ROM. Never loose that backup just in case you need to go back to stock, you'll need that backup. ROM manager is the easiest place to start for ROMs.
Thanks for the help
prospero44
