HELP ! :(
cbass15
9
Okay i went into recovery mode on my phone and i tried to flash the update.zip file and it installed and everything and now my phone wont boot up it stays on the gray LG screen, and i cant access recovery menu ive tried everything i could do and nothing works help
Try the directions in THIS thread. It sounds like you ran the update.zip file from a custom recovery, which isn't a good idea. You probably have a brick, but you may be able to bring it back.
Do you already have a custom recovery installed? If so, just do a full wipe of everything and reflash a custom rom. I'm assuming you're at least rooted. Basically, if you can get to recovery, you're not screwed. Otherwise, try the link bblaze provided.
Tried that and the software gives me an error saying fatal error help?
RESULTS:
14:06:58 : [C:\LGMobileUpgrade] ???丮 ???? ?õ?
14:06:58 : RemoveDirectory1 Error(2):C:\LGMobileUpgrade
14:06:58 : Start Date : 2012-01-12 14:06:58
14:06:58 : -------- Buyer Test mode ---------
14:06:58 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
14:06:58 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
14:06:58 : *****CheckOS Start********
14:06:58 : Microsoft_Windows_Vista Home Edition_
14:06:58 : *****CheckPCSyncPrograms Start*****
14:06:58 : PCSyncPrograms Not Found
14:06:58 : SetEmerModeAT()
14:06:58 : _IsConnectedPhone Call
14:06:58 : _IsConnectedPhone(0)
14:06:58 : 0 - NotConnected.
14:06:58 : 1 - Normal connect success
14:06:58 : 2 - Emergency connect success
14:07:51 : Checking the connection with the cell phone...
14:07:51 : dwWaitResetTime(40000 ms)
14:07:52 : _IsConnectedPhone Call
14:07:59 : _IsConnectedPhone(2)
14:07:59 : 0 - NotConnected.
14:07:59 : 1 - Normal connect success
14:07:59 : 2 - Emergency connect success
14:07:59 : Phone Mode(2)
14:07:59 : *****GetPhoneType Start*****
14:08:02 : Phone Type : CDMA
14:08:02 : *****Start GetPreviousStep*****
14:08:02 : _GetPreviousStep(dwStep:0xffff)
14:08:02 : *****GetPhoneBinaryVersion Start*****
14:08:02 : CSE mode -> Version Replace
14:08:02 : *****Get ESN / IMEI / MEID Start*****
14:08:14 : *****GetPhoneNumber Start*****
14:08:16 : Phone Number : 00000000000
14:08:17 : ???? ?˻? ?Ķ??Ÿ - ESN_IMEI : 00000000000, Model :
14:08:19 : _GetAuthMark : wAuthMark(30623)
14:08:19 : Wait 3Sec
14:08:25 : _SetAuthMark Ok : wAuthMark(30623), PhoneMode(2)
14:08:25 : *****CheckPCSyncPrograms Start*****
14:08:25 : PCSyncPrograms Not Found
14:08:26 : CLGMobileHttp Class ?Ҹ????.
14:08:26 : CLGMobileHttp Class ?Ҹ?...
14:08:26 : ****************CheckAndDownload********************
14:08:26 : ******Extract Start C:\LS670ZVC_11.SC_11.P60674.cab*****
14:08:26 : Model Dll Dir(C:\ProgramData\LGMOBILEAX\Phone\)
14:08:26 : ExtractInfo Error(0)
14:08:26 : Extract cab file error.
14:08:26 : [C:\ProgramData\LGMOBILEAX\Phone] ???丮 ???? ?õ?
14:08:26 : RemoveDirectory1 Error(2):C:\ProgramData\LGMOBILEAX\Phone
14:08:27 : !pUpgrade->StartProcessing ... PostMsg STEP_TYPE_ENV_ERROR
14:08:27 : CLGMobileHttp Class ?Ҹ????.
14:08:27 : CLGMobileHttp Class ?Ҹ?...
14:08:27 : Page_Error ?κ??Դϴ?
14:08:27 : OnStepMsg STEP_TYPE_ENV_ERROR delete m_pLGCyonUpdate
Looks like a trip to a Sprint store is in your near future. Make sure it is one with on-site techs (a corporate store). They may be able to help you. Chances are they are going to tell you it can't be fixed and will offer to sell you a refurb.
