Help!
mjp9775
75
Finally got my Rezound today :)
Now I need to know exactly how to copy music from my laptop to the phone so that I can get the stock music player to see the files. Can anyone help me out?
Is the music on your part in itunes or what!?
Sent from my ADR6425LVW using Tapatalk
Personally, I uploaded the music on my pc to my Google music account. Then I installed Google music app on my phone and access my music in the cloud.
Just copy your music directory to the external sdcard (to save space on the default internal sdcard) using your pc and the rezound connected as a disk drive. The music apps wil find it automatically.
The extenal sdcard is addressed at both /sdcard2 and /sdcard/ext_sd
The rezound has two sdcards, one internal (16gb) and one external ie removeable (16gb supplied). The internal sdcard is the default for the phone and apps which dont allow you to specifiy a directory so its best to keep space available on it.
It shows that i have 2 "devices with removable storage". One is Removable Disk F:, and the other says HTC Storage. Which one is the external card?
Should be the removeable storage one. you can check the remaining space. One a fresh rezound the internal sdcard has about 10.5gb free and the external sdcard has about 15gb free.
try double twist that how i put my phone on sd card and phone without cloud using. it similar to itunes set up
mitiku Berihe
