Q quejo Member May 20, 2010 10 0 0 Jun 13, 2010 #1 Using the ASTRO File Manager app...what are the steps in transferring my pics from phone memory to my sd card?
mclarryjr Retired Moderator Nov 2, 2009 5,546 874 113 Jun 13, 2010 #2 It would be much easier using a pc but if you need to use astro locate the pictures you want to move and long press and choose move then navigate to your scdcard and hit menu then select here.
K krelvinaz Well-known member Apr 21, 2010 344 6 0 Jun 13, 2010 #3 Should change the subject to something more useful like "Help with Pics using Astro"... You can also use the Multi function so that you can select multiple pictures to move/or copy at once instead of doing them one at a time.
