Help?
anon(894603)
70
Does this mean I can't update my phone even tho its on ICS?
Sent from my PH44100 using Android Central Forums
Hi Raun,
I guess you will have to follow the exact steps as written.
As for unlocking bootloader you can check this link: http://htcdev.com/bootloader/
For Custom Revovery go here: http://forum.xda-developers.com/showthread.php?t=1399321
BTW, are you facing any issues on your phone after ICS update ? Is it laggy ? Mine is ... and I'm too planning to get a custom one.
Thanks
Ok after I I do all of that, I can jus root it from that Site? And actually when I first downloaded there was A LOT of problems like all of my songs and pictures were gone, then I cut my phone off and took my battery out for a while and cut it on. After I left it for a while, it worked perfectly. I guess the update has to sit in for a while
elnilphamari
