Help
wendelin591
Hi there, I need help! My viewpad7 says I need to free up memory, how do I do that? And it does not picked up a very good wifi signal. Can I improve this somehow?
Welcome to AC!!
Uninstall some apps, move files/apps to your SD card, or you can root and remove bloatware.
As for WiFi signal, are you experiencing poor reception from multiple routers? Or have you only tested it with one? It might just be you have an old router.
mindpath
