Help...
revjong
19
Downloaded JB then ended up with an android on his back with an exclamation mark in a red triangle... :'(
What went wrong and how do I fix it?
Thank you in advance!
Do you mean the OTA?
You have a custom recovery, I presume? You must be stock to accept an OTA. Please check the OTA thread for instructions on how to install it manually :).
Sent from my Overly Suspicious Robotic Grouper
Used the toolkit to go back to stock image... turned on wifi and it is downloading it again
Will let you know how it turns out. Thanks!!!
heritagevines34
