HELP?!?!?!?!
Kelsey Iannazzo
Phone wont turn on or go into download mode. Was working fine last night around 1 am and when I woke up at 8 am it wouldnt turn on or go into download mode.Any information will help on how to get my phone to work again.
I should mention I have tried taking the battery out, I have tried charging it, I have tried 2 diffrent batteries. Nothing seems to be helping.
Leave it without a battery for about 2 or 3 minutes. Remove sim card and sd also. Reinstall battery and sim card and see if it boots. Also check that the power button moves when pressed. Plug it on the computer and see if it works. If that doesn't work, you might very well had a major haardware failure. Try a different charger and cable to rule them out. You might think it works or that the batteries are charged when they may not be charged due to a faulty charger or cable.
Sent from my SAMSUNG-SGH-I317 using Android Central Forums
MorriTinni
