Help!!
Tyler York
I want to root my phone.
My system version: 6.16.21.XT912.Verizon.en.US
Android version: 4.0.4
I am a novice, any pointers?!
It will be easier if you wait for the update to hit you. That way you won't have to unroot and then reroot. They are rolling the update out NOW. It might take you a week to get it. At this point, might as well wait.
When you DO get the update, the first thing you should do is get Voodoo OTA Rootkeeper and follow the instructions as you root. This makes it really easy to unroot when the next update rolls around. After you update, you can reroot.
Since you are still on ICS you will be able to root with no problem. Search around for matt's utility and use it accordingly.
BTW don't listen to the guy before me as if you take JB update you will not be able to root then.
DumpedDuce Approves This Message
odigon
