Help
Mikkey Smiles
my phone's actually called the "L7" but i think its also called "G"
my messaging crashes
music doesn't stay in playlists
instagram and other apps crash A LOT!
i can't connect to the computer
i don't have "Mass storage mode"
Does anyone else phone do this??
interns of the apps crashing, which apps are they ?
certain apps also crash on my phone (htc EVO 3D running ics)
have you tried a factory reset to fix all your problems ?
to do a factory reset go: Settings > storage > reset data (it should be somewhere at the bottom)
note: I do not own an LG or ginger bread device so the instructions may be wrong for your device.
Instagram and temple run but even if I go on the internet it's really slow even o I have 4 wifi bars
yes I have factory reset it, didn't work
sent it back to the phone company to be fixed, didn't work...
I'm just getting a new version of the same phone but I was wondering if happened to anyone else
This has been a problem for me ever since I got the phone last November. I get 'Unfortunately messaging has stopped' error 2-3 times daily. Have tried clearing app data and factory resets. Didn't work. Thought the firmware update back in January and the Jelly Bean update might fix it. It did not. Still have the problem.
Cam12
