Sounds broke. Any suggestions would require you to be able to see setup. I know that on screen brightness you can make it white (or black) but if you can't see anything you can't check much. Is it a type that you can plug into another monitor or HDMI into the TV. You can't touch the screen but you would know if the display is blown out. Sorry but that's all I have.
