Help!!!!!
OwnDreamChaser
3
Every time I plug in my earphones into my HTC One X, it starts calling the last dialed number automatically and starts the music after short interval. And earphone icon is still on the top when earphones are not connected whit phone. What the bug is this?Help me :)
Have you tried turning off the phone then turning it back on? Let me know if that doesn't work.
It do not worked :( Same problem when I connected my phone whit earphones after shutting down and turning it beck.
You can try two things. One is to hard reset the phone. the other is to download this app which allows you to reroute the audio to your speakers.
Thanks for helping:) I downloaded the app, but that's not solution in long time run. What tipe of bug is that? In future I will reset my phone. What will happen when I reset it? All apps will be gone?
You data will be wiped clean. Back up music, pictures, whatever you feel is important.
Sent from my One X using Tapatalk 2
MorriTinni
