Help?
anthonytward
17
Ok , so I have a rooted N4 with TWRP installed and I want to use the OTA 4.4 DL. My phone show the 4.4 is ready, so the DL complets and reboots into TWRP it's then I get lost as I can't see the new SW in the menu!. How can I load the new 4.4?
Thanks
OTA Fails to install Android 4.4
I had the same exact problem yesterday where the OTA made no changes and put me into TWRP recovery. It could be an issue with TWRP or my phone not being completely stock. Here is how I got it to install using fastboot:
1) Under "Factory Images "occam" for Nexus 4" I downloaded "4.4 (KRT16S)".
https://developers.google.com/android/nexus/images#occamkrt16s
2) I then followed these directions (WARNING: Note the instructions to remove the "-w" from the flash-all.bat file before you run it. This will retain all your existing data, apps, settings, etc.).
http://forum.xda-developers.com/showthread.php?t=2527142
3) I then installed the latest versions of TWRP and superuser.
You might want to put a more descriptive title in your thread like "OTA Fails to Install Android 4.4"
tombwiz14
