HELP!
Tijana Lukic
Hi guys. I have data conn. problem. I see that if I reset APN or something,the problem will be solved..but..in my settings,I DON'T HAVE ACCESS POINT NAMES.(only blank page) :O plz help me... :( btw I'm using go clever Quantum 4 if it helps..
P.S. Sorry for bad english :(
Are you using 2 SIM cards or just one? If one, have you tried switching it to the other slot? The phone should auto set based on the SIM card. Can you borrow someone else's card who is on a different network to force it to auto set and then swap back your card forcing the reset again?
okikisodiq234
