• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
help
Shargeel Kiani
43
Im using nexus 5, after the update to lollipop( which i updated 15days ago) ,my battery timing had increased... But recently something bad happened and my battery life is decreased to great extent, any solutions?
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,250
A reset being completely reset the device so you have to set it up all over again. Back up any files you don't want to lose, and then in Settings, there should be a backup and reset option. Click on that.
daihard2008
324
This is probably a basic question. When you do a factory reset, will it erase the user data stored on the /sdcard partition as well?
Golfdriver97
Moderator
Dec 4, 2012
35,250
In my experience, it has gone both ways. I have had data wiped, and not. I always go under the assumption that data will be lost when a reset is done.
Edit: and external card should be fine, but when I had devices that took them, I always unmounted them just in case.
Shargeel Kiani
43
Well its working fine nw after full charge and doing some settings. Actually i had set backlight time fr 5min, now i set it fr 15sec, an battery graph is bck to normal.
daihard2008
324
That makes me wonder if the user data on the "internal" storage mounted as /sdcard/ will be wiped as well. Even though it is truly an internal partition, its name suggests that Android may treat it like an external one. Any thoughts on this?
Golfdriver97
Moderator
Dec 4, 2012
35,250
I would have thought the personal data should be safe. But then again, I think the last time that happened was on my S2 which was partitioned in such a strange way.
