jharned
15
i got captivate...i want to transfer pictures from phone to sd card. How can i do that??? second, how can i unsync gmail account from it??? Last, how can make a picture fit without being blown up??? i'm one lost goose
DroidXcon
11,100
3,392
plug your phone into the computer, pull down the notification bar , select the USB notification, select mount ,,,,this will mount the sdcard and the phone internal storage on your pc, then you can copy paste or drag out the pictures at will
settings>accounts & sync > choose your goole account, this will give you options on what to sync and what not to sync
the picture needs to be 400x800 i believe, or vice versa
Reactions: jharned
mamawM
234
13
when you take a picture with your android phone they are automatically stored on the sd card, no need to copy from phone to sd.
anoyyy
