Help
dlgus
526
18
Appealing to the collective.
See attached pix. How can I get the starred words to look like the other words?
Hitting the big 60 and my eyes aren't what they used to be.
Are you using any themes? Those might change the color and way UI elements look on screen. The Note also has options in your phone's Settings (Settings/Accessibility/Vision) to change color schemes to high-contrast and bigger text.
Go to Settings, Accessibility, Vision and turn off the switch for high contrast fonts.
thank you, but what I want is for the starred area words to not look like cutouts.
Exactly what turning that switch off does. With it on, it looks like what you show above, which you don't want, correct?
Just a friendly reminder that on any internet forum, it's helpful and courteous to use an informative subject line. That way, people can tell at a glance which threads they want to read or contribute to, and they can more easily find their way back to specific threads later. Imagine if all the subject lines were like "I need help", "Has anyone seen this?", "Angry and frustrated", "I have a question", etc. They'd be indistinguishable from one another.
vicinity
