Hi major problem with installing big apps
craig lund
6
Hi if I try to install anything bigger than 1MB my phone automatically says (in play store) Package file invalid. If I try install an app directly from apk it fails please help! Thank you
1. Most carriers limit the amount you can download, if this isnt the issue read option 2.
2. If you go Settings --> Programs --> Manage Applications, then check under "Downloaded" and "On SD Card" and see how much space you have there ?
3. Try re-installing Google PlayStore
Also what version/phone are you currently using this might benefit me helping.
I've done all of the above I have a 16mb sd card I've even master reset the phone
Richie Q
