High battery usage on Galaxy Note 8.0
Brahmanda Gede
My screen usage has been like this for two weeks.
I'm already uninstalled most app and removing my photo an video in my device, and nothing changed.
Usually my screen battery usage was under 40 percent.
Did anyone know to fix this?
Sorry for my bad english.
Welcome to Android Central! The percentage isn't as important as the total time the screen has been on. Remember that the percentage is relative--so that if you're doing less of other activities on the device, then the screen will be responsible for more of the overall battery usage. What is your total screen-on time?
Open up the back and disconnect the battery for an hour. You can open up the back with either a plastic pry tool or I use my finger nails. If you need to see how to disconnect the battery wire heres a video. DONT UNSCREW IT lol just saying. you can skip to 4:47 to where they disconnect it. https://www.youtube.com/watch?v=sZG28TPmd8Y
tonga94
