I think he meant getting a raw file like png rather than jpeg but that's good info for max resolution.
No, I was talking about what digital cameras call "quality". This is the compression ratio. The less compression the higher quality (within mp and lens limits). The camera on the TB has no "Quality" setting (i.e. compression amount).That's what I was thinking but with this phones RAW or TIFF are not an option. Beside the MB would change base on the settings he has at the time a picture was taken. Darker images will be less MB but on a good lighting MB will increase.
Yes, you need to unselected Widescreen which would now give you 3264 x 2448 which would equal 8.5 mp. The 3264x1952 size is actualy a 6.7 mp quality.
If only it were that simple. But it's not. Physical sensor size is important, but there are these other things that are just as important. They all need to match up to achieve the best possible image. It does no good to have one that is way better than another (the bottleneck). Sensor area is just one thing.Well at the end it come down to the image sensor cell phone use much smaller.
