Holster For Dinc With 2100 Battery Found.
The only ones on there for the Inc are the Seidio InnoII holster and they won't work with the 2150 battery because you have to have the InnoII case which only fits the regular door on the phone. If you mod the case you can fit it on there because the battery faces out.
If I missed what you are talking about give us a direct link to the product.
Sorry redid the link hope it works, new to Google Chrome so I must have cut the wrong link.
try this view-source:HTC Incredible Spring Clip Holster by Seidio
Its just the holster, I haven't found a case. Works very well.
I bought the Seidio Spring clip and I like it a lot. It’s sturdy and holds the phone securely. I'm even tempted to get the 3500 battery since it will fit the clip! :)
I got my clip holster from HandHelditems.com for $4.99. Works with both stock and 2150 extended battery.
Yeah that's the Seidio clip, it will work with any battery. Just make sure you get the one that doesn't require you have the case too and you should be golden. I wasn't even aware they had the non-case version out yet!
Beboomo
