Holster with the body glove case.
tsak6789
147
Anyone know of a holster, or belt clip that can be used with the Body Glove case?
I like the one from seido, but doubt that will fit with the body glove case
I know this doesn't help you out too much, as my holster doesn't have a name on it.
But I went to one of those phone case kiosk at the mall. (funny that the guy running it had an EVO too.)
But ask him about holsters for the EVO. Regualar one for the evo wouldn't work. but he had another and it works perfect with my phone and cover(I have rocketfish cover).
It is pretty nice. Leather, magnetic closure, soft inside, and it was only like $20.
Just saying you might want to give a place like that a try, as they are usually pretty good about letting you try several before you buy so you know exactly what your getting.
I too have the $20 RocketFish belt case from BestBuy and the BG hardshell fits nicely in there.
... but now the "belt clip" is starting to widen out, and it's fallen off my belt a couple of times. It's gonna be hard to mash this back together, so I'm not sure what to replace it with.
I traded in my Body Glove case for the $30 best buy case with plastic clip.
I have always prefered to use clips instead of actual pouches. I found a great one for the Hero at a Sprint Store and it made my phone experience a little better. Now that i have an EVO, i still prefer the outer case with a clip in type holder. Makes getting to the phone faster.
The big difference for me is about every other week i would randomly do a battery pull. I know i dont need to but i like to. With the body glove case i would feel as if i might break it when trying to get it off. This new case i have slides on from the top and bottom and meets in the middle. That makes it a lot easier to get off in case i need to remove the battery or get to the memory card. It also seems to cover the sides and corners a little better.
Have you considered turning the device off instead of a battery pull? I did the battery pull for the first 2 weeks and have noticed that turning it off/on does the same for me.
chandrest
