Home screen help
jm_nels
3
I am setting up my homescreen on my droid x and have run into a bit of a problem. First I like to have only one homescreen so what I do is set up 4 or so folders on that screen thus eliminating the need for the other screens.
I want to set up a "toggle" folder and have all of my toggles in that folder but I am not able to do this.
Any help?
If you would like to only use one homescreen, I think the only way to do that is with a different launcher such as LauncherPro (what I use) or possibly ADW Launcher (I don't know if this has custom number of homescreens).
Since there isn't a way to set up a "toggle" folder, I would recommend an application called "Quick Settings". I also use this and I open up the applicaton and it has a customizeable list of settings and toggles.
LauncherPro on AppBrain
ADW.Launcher on AppBrain
Quick Settings on AppBrain
kali-arm64
