Honeycomb Problem
mickeymutt
Hi,
I just installed Honeycomb internally. Everything seems to be ok. but when I try to install apps I receive an error message "Download unsuccessful, Please try again". Also, I now can't get to my library. Which would be the best. Install the B&H app or re-do honeycomb to the sd card to dual boot.
thanks...MickeyMutt
do you have a mounted SD card? I've found a lot of apps will fail install unless i unmount the SD card.
Thanks for the advice. But, sorry it didn't work. I guess I'll un-root the NC and see how the new up-dates from B&H works.
tabpro
