Honor 5X and AT&T
KN4S
5
Is there anyone out there using the Honor 5X with AT&T?
If so, do you have any problems with MMS messaging or Internet service using data and not wi-fi?
If your set up is working, would you do me a favor and send me a copy of your APN (settings, more, mobile network, access point names) that you are using. I have worked with AT&T tech support and nothing they have suggested has worked.
Maybe if I can get a copy from someone that works on AT&T, I can configure mine as the same.
The customer service rep said sometimes with off brand unlocked phones they had problems.
Any information anyone can provide will be appreciated.
Harry
I've had no issues with mine on att. Under APN's are you on ATT next gen phone?
Posted via the Honor 5x on Android 6.0.1
