Hot spot issue
Rumblee1
Trusted Member
Nov 3, 2012
1,610
48
48
Hi all, happy holidays. I have an S21 ULTRA that I've had since launch and it's been great. Even though it's been a while, I'm using the HOT SPOT feature for the first time. I notice that this feature is not remaining on. Does it go off by default when no other device is using it? As long as another device is using it, will it remain on? Thanks.
Yes, normal operation.
To configure:
Configure Mobile Hotspot​
Timeout Settings​
    • From a Home screen, swipe up or down from the center of the display to access the apps screen.
      These instructions only apply to Standard mode and the default Home screen layout.
    • Navigate:
      Settings
      Settings icon
      Connections
      Mobile Hotspot and Tethering
    • Tap
      Mobile Hotspot
    • Tap either 'Network name', 'Password' or 'Band' to enter the Configure Mobile Hotspot menu.
    • Tap
      Advanced
    • Tap
      Turn off when no device connected for
      then select an option (e.g., Never timeout, 5 minutes, 10 minutes, 60 minutes, etc.).
Reactions: B. Diddy
Same thing happens on my Pixel 7 Pro as well. Hotspot uses more battery, so an auto-shutoff when no connected devices are detected is a good idea.
Reactions: Laura Knotek
If you have it toggled for no device to turn off but also if you have enough hot spot Data?
That be from your carrier
BrüZZi
