How can I adjust the volume on a call?
mhwombat
Keypress volume when dialing a number manually
When I place a call by dialing the number manually, the volume as I press each number is very loud. How can I adjust this volume or turn off the sound? This problem occurs only when dialing a number; key presses at other times are silent. This is on Android 4.2.
VidJunky
5,653
462
83
Re: Keypress volume when dialing a number manually
What device do you have?
Under Sound in the settings for Keypad touch tones you can turn them off or try a short tone it may not quiet it down but it may reduce it to a point that it isn't as much of an issue for you.
mhwombat
I have a Fairphone.
I found a solution. Go to Settings --> Audio profiles and tap the icon to the right of the profile you want to disable the dial pad sound for, then scroll down to the "System" section and uncheck "dial pad touch tones". this worked for me.
