How can I fix annoying system popups
redclou111
3
Hello, all.
For some reason, I am getting constant system popups at the bottom of my screen, especially after I connect or disconnect WiFi or Celluar Data. I have turned off WiFi network notifications. I have also used Titanium's Freeze feature to freeze many apps I thought might be causing this. I also can't find any Android system settings that will stop this problem. If anyone has a solution, I will greatly appreciate hearing it.
Here is a link to a screenshot with the popup.
https://dl.dropboxusercontent.com/u/51890636/screenshot.png
Thanks!
Welcome to Android Central! Any options turned on in Settings>Developer Options​?
cany
