How can I fix some LG G4 problems?
  • Start date Start date
A
AC Question
lg g4 problems
Yesterday my phone started restarting by itself and now is dead and wont power on... Everyone now and then i can remove battery and sim and put back in and it comes on for a couple seconds but then turns right back off.. Is there anything i can do to fix it? T-mobile is sending me a new battery , hopefully that fixes it ! thx
Re: lg g4 problems
Yea could be a battery issue, you could try taking the battery out and then plugging the charge cable into a PC.
Plug the charge cable into the phone and then immediately put the battery in, it might work.
Otherwise if its not a battery issue then you will have to factory reset.
dakiddsolodolo88
